Uran79
Uran79
Ярославль
01.11.2014 в 22:47:24
Доброго. Нужен перфотатор скажем так для нечастого сверления (более того крайне эпизодического) сверления небольших по диаметру (до 10мм включительно) и небольших по глубине (до 5-8 см) отверстии в кирпиче/бетоне
Что присоветуете вот из этого взять ? http://www.vseinstrumenti.ru/perforatori-r32.html/show_cat.php?formType=param&cat_id=32&height=&price%5Bfrom%5D=1837&price%5Bto%5D=5000&price%5Bon%5D=1&price%5Btype%5D=slider&price%5Bmin%5D=1837&price%5Bmax%5D=37500&makes%5Bids%5D%5B3%5D=on&makes%5Bids%5D%5B24%5D=on&makes%5Bids%5D%5B1%5D=on&makes%5Bon%5D=1&makes%5Btype%5D=check&bdc%5B1085%5D%5Bids_false%5D=&bdc%5B1085%5D%5Bon%5D=1&bdc%5B1085%5D%5Btype%5D=check&bdc%5B507%5D%5Bids_false%5D=&bdc%5B507%5D%5Bon%5D=1&bdc%5B507%5D%5Btype%5D=check&bdc%5B635%5D%5Bfrom%5D=420&bdc%5B635%5D%5Bto%5D=2000&bdc%5B635%5D%5Bon%5D=1&bdc%5B635%5D%5Btype%5D=slider&bdc%5B635%5D%5Bmin%5D=420&bdc%5B635%5D%5Bmax%5D=2000&bdc%5B204500%5D%5Bfrom%5D=1.2&bdc%5B204500%5D%5Bto%5D=29&bdc%5B204500%5D%5Bon%5D=1&bdc%5B204500%5D%5Btype%5D=slider&bdc%5B204500%5D%5Bmin%5D=1%2C2&bdc%5B204500%5D%5Bmax%5D=29&bdc%5B2070%5D%5Bfrom%5D=24&bdc%5B2070%5D%5Bto%5D=160&bdc%5B2070%5D%5Bon%5D=1&bdc%5B2070%5D%5Btype%5D=slider&bdc%5B2070%5D%5Bmin%5D=24&bdc%5B2070%5D%5Bmax%5D=160&bdc%5B2069%5D%5Bfrom%5D=12&bdc%5B2069%5D%5Bto%5D=80&bdc%5B2069%5D%5Bon%5D=1&bdc%5B2069%5D%5Btype%5D=slider&bdc%5B2069%5D%5Bmin%5D=12&bdc%5B2069%5D%5Bmax%5D=80&bdc%5B204068%5D%5Bids_false%5D=&bdc%5B204068%5D%5Bon%5D=1&bdc%5B204068%5D%5Btype%5D=check&bdc%5B206048%5D%5Bids_false%5D=&bdc%5B206048%5D%5Bon%5D=1&bdc%5B206048%5D%5Btype%5D=check&bdc%5B244%5D%5Bids_false%5D=&bdc%5B244%5D%5Bon%5D=1&bdc%5B244%5D%5Btype%5D=check&bdc%5B206420%5D%5Bids_false%5D=&bdc%5B206420%5D%5Bon%5D=1&bdc%5B206420%5D%5Btype%5D=check&bdc%5B2071%5D%5Bfrom%5D=2&bdc%5B2071%5D%5Bto%5D=6&bdc%5B2071%5D%5Bon%5D=1&bdc%5B2071%5D%5Btype%5D=slider&bdc%5B2071%5D%5Bmin%5D=2&bdc%5B2071%5D%5Bmax%5D=6&bdc%5B168%5D%5Bfrom%5D=1.5&bdc%5B168%5D%5Bto%5D=11.6&bdc%5B168%5D%5Bon%5D=1&bdc%5B168%5D%5Btype%5D=slider&bdc%5B168%5D%5Bmin%5D=1%2C5&bdc%5B168%5D%5Bmax%5D=11%2C6#searchRes
Хотелось бы конечно полегше по весу.
или что-то другое ?
или мне вполне хватит ударной дрели ? если да то какую модель лучше взять из вот этих ? : http://www.vseinstrumenti.ru/instrument/dreli/udarnye/show_cat.php?formType=param&cat_id=13&height=&price%5Bfrom%5D=651&price%5Bto%5D=5000&price%5Bon%5D=1&price%5Btype%5D=slider&price%5Bmin%5D=651&price%5Bmax%5D=21300&makes%5Bids%5D%5B3%5D=on&makes%5Bids%5D%5B24%5D=on&makes%5Bids%5D%5B1%5D=on&makes%5Bon%5D=1&makes%5Btype%5D=check&bdc%5B614%5D%5Bfrom%5D=450&bdc%5B614%5D%5Bto%5D=1400&bdc%5B614%5D%5Bon%5D=1&bdc%5B614%5D%5Btype%5D=slider&bdc%5B614%5D%5Bmin%5D=450&bdc%5B614%5D%5Bmax%5D=1400&bdc%5B1780%5D%5Bids_false%5D=&bdc%5B1780%5D%5Bon%5D=1&bdc%5B1780%5D%5Btype%5D=check&bdc%5B204361%5D%5Bids_false%5D=&bdc%5B204361%5D%5Bon%5D=1&bdc%5B204361%5D%5Btype%5D=check&bdc%5B569%5D%5Bfrom%5D=10&bdc%5B569%5D%5Bto%5D=35&bdc%5B569%5D%5Bon%5D=1&bdc%5B569%5D%5Btype%5D=slider&bdc%5B569%5D%5Bmin%5D=10&bdc%5B569%5D%5Bmax%5D=35&bdc%5B567%5D%5Bfrom%5D=15&bdc%5B567%5D%5Bto%5D=50&bdc%5B567%5D%5Bon%5D=1&bdc%5B567%5D%5Btype%5D=slider&bdc%5B567%5D%5Bmin%5D=15&bdc%5B567%5D%5Bmax%5D=50&bdc%5B571%5D%5Bfrom%5D=6&bdc%5B571%5D%5Bto%5D=22&bdc%5B571%5D%5Bon%5D=1&bdc%5B571%5D%5Btype%5D=slider&bdc%5B571%5D%5Bmin%5D=6&bdc%5B571%5D%5Bmax%5D=22&bdc%5B735%5D%5Bids_false%5D=&bdc%5B735%5D%5Bon%5D=1&bdc%5B735%5D%5Btype%5D=check&bdc%5B739%5D%5Bids_false%5D=&bdc%5B739%5D%5Bon%5D=1&bdc%5B739%5D%5Btype%5D=check&bdc%5B1555%5D%5Bfrom%5D=2&bdc%5B1555%5D%5Bto%5D=4&bdc%5B1555%5D%5Bon%5D=1&bdc%5B1555%5D%5Btype%5D=slider&bdc%5B1555%5D%5Bmin%5D=2&bdc%5B1555%5D%5Bmax%5D=4&bdc%5B129%5D%5Bfrom%5D=1.4&bdc%5B129%5D%5Bto%5D=4.5&bdc%5B129%5D%5Bon%5D=1&bdc%5B129%5D%5Btype%5D=slider&bdc%5B129%5D%5Bmin%5D=1%2C4&bdc%5B129%5D%5Bmax%5D=4%2C5#searchRes или есть другие варианты ?
бракодел
бракодел
Ярославль
01.11.2014 в 22:52:59
Uran79, если вы состоите в клубе трудолюбивых мальчиков то можете сверлить бетон дрелью . если сверление действительно редкое то перф любой из того списка . если таки регулярно то зеленый бош лучше отсеять
dokar
dokar
Мадонатор
01.11.2014 в 22:56:54
Uran79,
Uran79 написал : до 5000р
Макака 1830 , но бурит тоскливо . Единственное преимущество её слабого удара это не так сильно разбивает на входе в бетон. И процентов 60-70 будут советовать именно её, или П 18.:)
Да, ни фига.
Vollob
Vollob
Тула
02.11.2014 в 00:13:29
Так же посоветую Макиту HR 1830. Использую такую как дюбельник. При сверлении отверстий на 6 и 8, самое то. Несмотря на то что Джоулей мало, справляется отлично. При этом вес перфа, как у маленькой дрели. Правда он сильно подорожал. Я, год назад, брал за 3800 руб.
Valmemst
Valmemst
02.11.2014 в 00:21:35
Uran79, Посмотри новейшую Макиту 2230, она на лезвие бритвы дороже 1830, но намного новее и мощнее.
Anat78
Anat78
Серов
02.11.2014 в 03:05:37
Uran79 написал : Что присоветуете вот из этого взять ?
любой из этих http://www.vseinstrumenti.ru/perforatori_s_patronom_sds-plus-r374.html/show_cat.php?formType=param&cat_id=374&height=&price[from]=1938&price[to]=5338&price[on]=1&price[type]=slider&price[min]=1938&price[max]=26100&makes[ids][407]=on&makes[ids][24]=on&makes[ids][59]=on&makes[ids][1]=on&makes[ids][35]=on&makes[on]=1&makes[type]=check&bdc[1085][ids_false]=&bdc[1085][on]=1&bdc[1085][type]=check&bdc[507][ids][9584]=on&bdc[507][ids_false]=&bdc[507][on]=1&bdc[507][type]=check&bdc[635][from]=420&bdc[635][to]=1850&bdc[635][on]=1&bdc[635][type]=slider&bdc[635][min]=420&bdc[635][max]=1850&bdc[204500][from]=1.2&bdc[204500][to]=7&bdc[204500][on]=1&bdc[204500][type]=slider&bdc[204500][min]=1%2C2&bdc[204500][max]=7&bdc[2070][from]=24&bdc[2070][to]=100&bdc[2070][on]=1&bdc[2070][type]=slider&bdc[2070][min]=24&bdc[2070][max]=100&bdc[2069][from]=12&bdc[2069][to]=36&bdc[2069][on]=1&bdc[2069][type]=slider&bdc[2069][min]=12&bdc[2069][max]=36&bdc[204068][ids_false]=&bdc[204068][on]=1&bdc[204068][type]=check&bdc[206048][ids_false]=&bdc[206048][on]=1&bdc[206048][type]=check&bdc[244][ids_false]=&bdc[244][on]=1&bdc[244][type]=check&bdc[206420][ids_false]=&bdc[206420][on]=1&bdc[206420][type]=check&bdc[2071][from]=2&bdc[2071][to]=5&bdc[2071][on]=1&bdc[2071][type]=slider&bdc[2071][min]=2&bdc[2071][max]=5&bdc[168][from]=1.5&bdc[168][to]=8&bdc[168][on]=1&bdc[168][type]=slider&bdc[168][min]=1%2C5&bdc[168][max]=8&asc=ASC&orderby=price#goods
spawn54
spawn54
Забанен
02.11.2014 в 14:25:41
бракодел написал : Uran79, если вы состоите в клубе трудолюбивых мальчиков то можете сверлить бетон дрелью . если сверление действительно редкое то перф любой из того списка . если таки регулярно то зеленый бош лучше отсеять
800
да и соседа с ударной дрелью всегда хочется застрелить))
Mutru4
Mutru4
Тамбов
02.11.2014 в 23:37:57
у нас обновленный бош 2-24, пятёрку стоит:)
сталкер14
сталкер14
Махачкала
03.11.2014 в 00:23:56
Вот это и надо выбирать
Serg
Serg
03.11.2014 в 18:29:56
Из ИНТЕОСКОЛовских перфораторов я бы порекомендовал вот этот - http://www.interskol.ru/catalog/betonoobrabotka-i-otdelka/perforatoryi/perforatoryi_2.html Хороший запас мощности, достаточно высокая скорость бурения и сам инструмент выпускается с 2008 года - уже хорошо проверен.
ИЗЯ ДУЛИН
ИЗЯ ДУЛИН
Белгород
04.11.2014 в 21:08:27
Uran79 написал : для нечастого сверления (более того крайне эпизодического) сверления небольших по диаметру (до 10мм включительно) и небольших по глубине (до 5-8 см) отверстии в кирпиче/бетоне
Ударной дрели 750-800 вт вполне хватит.
