26.11.2018 в 18:56:51
Четыре треугольника. Угол вершины 60° 12-spline flange Screw Head - Spline.svg
The 12-spline flange screw drive has twelve splines in the fastener and tool. It consists of 12 equally spaced protrusions, each with a 60° angle. It is achieved overlaying 4 equilateral triangles, each one rotated 30° over the previous one. The spline drive was part of the obsolete, U.S-designed Optimum Metric Fastener System and was defined by ASTM B18.2.7.1M, which was withdrawn in 2011,[65] making the spline drive obsolescent. Spline drives were specified for 5, 6.3, 8, 10, 12, 14, 16, and 20 mm size screws[66]. Its primary advantage is its ability to resist cam out, so it is used in high-torque applications, such as tamper-proof lug nuts, cylinder head bolts, and other engine bolts.
Три квадрата Угол вершины 90° Triple-square Screw Head - Triple Square.svg
The triple-square, also known as XZN, is a type of screw drive with 12 equally spaced protrusions, each ending in a 90° internal angle. Common sizes are 6, 8, 10, and 12 mm. The name derives from overlaying three equal squares to form such a pattern with 12 right-angled protrusions (a 12-pointed star). In other words, three Robertson squares are superimposed at a successive 30° rotation. The design is similar to that of the double-square—in both cases, the idea being that it resembles a square (Robertson) but can be engaged at more frequent angles by the driver bit. These screws can be driven with standard Robertson bits.
The 12-pointed internal star shape superficially resembles the "double hex" fastener head, but differs subtly in that the points are shaped to an internal angle of 90° (derived from a square), rather than the 120° internal angle of a hexagon. In practice, drivers for the fasteners may or may not interchange, but should be examined carefully for proper fit before application of force. A hex key should not be used where a key of square cross-section is the correct fit.
Triple-square drive fasteners have been used in high-torque applications, such as cylinder head bolts and drive train components. The fasteners involved have heads that are hardened and tempered to withstand the driving torque without destroying the star points. They are commonly found on German vehicles such as Audi, BMW, Opel, Mercedes, Porsche and Volkswagen.[43]
Два шестигранника. Угол вершины 120° 12-point Screw Head - 12-Point external.svg
A 12-point screw drive uses two overlapped hexagon shapes, one rotated by 30º. Standard 12-point hex socket bits and wrenches fit these screws. The screw heads are typically flanged, and may fit into standard Allen hex socket cap screw counterbores molded or machined into parts to be fastened. Compared to Allen hex sockets, the advantages of these bolts include higher torque capability and the lack of a recess to trap water. A disadvantage is the extra cost involved in forming the heads.
maestro@
maestro@
26.11.2018 в 19:03:04
Alex___dr написал: 12-гранных головок болтов как минимум три вида, с разными углами при вершинах.
Ну значит три вида. У GEDORE есть 12-ти гранные головки на четверть. Начинаются от 4 мм. Профиль UNIT-DRIVE https://pneumatic-tools.ru/catalog/ruchnoy_slesarnyi_instrument/golovki_udliniteli_vorotki_kardany/torcevye_golovki/golovki_torcevye_14/golovki_torcevye_12_grannye_14/ Значит и крепеж есть для этих головок.
rumb
rumb
Рига
26.11.2018 в 19:05:57
$GLOBUS$ написал:
з.ы. Есть люди, которым никто не может доказать, что земля круглая. У них доводов много.
$GLOBUS$, Это кстати головка STAHLWILLE 6pt с профилем AS Drive. Сфоткайте так же простую 6гранную голову. Весь спор ведь не из-за 6 VS 12, а в том, что maestro@ писал, что БЕЗ супер новомодных профилей 6граней лучше, чем 12граней с профилем и даже лучше, чем 6граней с профилем! Во как.
maestro@
maestro@
26.11.2018 в 19:12:08
rumb написал: Это кстати головка STAHLWILLE 6pt с профилем AS Drive. Сфоткайте так же простую 6гранную голову. Весь спор ведь не из-за 6 VS 12, а в том, что maestro@ писал, что БЕЗ супер новомодных профилей 6граней лучше, чем 12граней с профилем и даже лучше, чем 6граней с профилем! Во как.
Давайте для порядку сначала с 12-ти гранными закончим, а будет желание, плавно перейдем на 6-ти. Вы расскажите свое мнение, обратив взор на фото с головками - у скольки гранной бОльшая площадь прелигания к крепежу?
maestro@
maestro@
26.11.2018 в 19:27:13
rumb написал: maestro@ писал, что БЕЗ супер новомодных профилей 6граней лучше, чем 12граней с профилем и даже лучше, чем 6граней с профилем! Во как.
Напомню что я писал:
maestro@ написал: Я к тому, что в данном случае, шестигранные головки хороши, а на больших размерах шестигранного крепежа (которые попрочней) 8,8 и 12,9, тоже шестигранные хороши. 12-ти гранные и прочие с хитрыми профилями для более мягкого крепежа наверное.
Прочие и с хитрыми профилями, касалось и шести и двенадцатигранных вариантов головок, так как обычные 6-ти гранные головки, в основном не портят крепеж с большой твердостью. Скорей головка треснет или шляпа крепежа отлетит (зависит от размера крепежа).
rumb
rumb
Рига
26.11.2018 в 20:05:14
maestro@, Мое мнение такое - 12гр. более универсальны, это и так понятно. Где универсальность, там приходится чем - то жертвовать: не много проигрывают 6 гр. на плохом крепеже. На нормальном крепеже вряд ли 12гр. уступят 6гр. Срыв граней так же зависит и от производителя инструмента, насколько головка пластична, тверда, толщина стенок, профиль в конце концов и т.д. Если человек работает профессионально и с утра до ночи постоянно сталкивается с проблемным крепежом, то да, 6гр. ударных головок ему в помощь и гайковерт мощнее. Но такие тут не сидят, нет у них времени крутить шары... :)
Для гайковертов 6гр. безусловно необходимость.
maestro@
maestro@
26.11.2018 в 20:09:47
rumb, Повторюсь -
maestro@ написал: А вообще, чем больше разных вариантов ключей, для откручивания крепежа, тем лучше. И рожковые нужны и накидные и головки с разным количеством граней и разными профилями и т.д. Только я против того, что бы во всех случаях, пользоваться исключительно каким-то одним универсальным вариантом. Любой из перечисленного может когда-то оказаться единственным верным вариантом.
26.11.2018 в 20:17:23
maestro@ написал: Ну значит три вида.
Три вида с треугольными зубцами.
maestro@ написал: У GEDORE есть 12-ти гранные головки на четверть. Начинаются от 4 мм. Профиль UNIT-DRIVE
А у Kabo есть профиль SPHERICAL ... http://catalog.forsunka.com/wp-content/uploads/2014/10/kabo_light_5.pdf
maestro@
maestro@
26.11.2018 в 20:26:34
Alex___dr написал: А у Kabo есть профиль SPHERICAL ...
Да, но они позиционируются как универсальные. Обратите внимание на картинки - с каким зазором сидит практически весь крепеж, который не имеет соответствующее инструменту количество граней, в таком профиле. Таким образом можно еще и треугольник разместить и еще что нибудь, но это не значит, что такое решение лучшее.
26.11.2018 в 20:45:33
maestro@ написал: но это не значит, что такое решение лучшее.
Естественно. Специализированный инструмент всегда лучше универсального.
ADM05
ADM05
Президент
Красноярск
27.11.2018 в 11:28:43
не_китаец написал: были у меня комбинированные ключи с шестигранной накидной частью. Много ими паршивого перетянутого крепежа было кручено. Интересно, сейчас у кого есть такие в продаже?
КАВО, серия PKS, ещё встречаются в продаже в этом году.
ИМХО (IMHO)
