ChVA
ChVA
14.03.2010 в 16:58:04
Кстати, насчёт это пилы (Milwaukee) есть и такие отзывы:
To start I have no bias in this review whatsoever, I am in construction and I run a crew of guys who work for me daily. My interest is in finding the best and most reliable tool. I keep multiples of most types of tools on hand and they are all used regularly. I usually buy the "best" of what is out there because the cost of downtime and replacement is not worth the time/cost to me.
I bought this tool from Amazon a few weeks before this review date. At the same time I bought a Makita 15 AMP and Hitachi 13 AMP. The other 2 saws are still working the SawZall is not. I was initially put off by the fact that the Makita was made in China, but it cuts very well and is very heavy duty. The only thing that is weird with the Makita is the mechanism that holds the blade is a bit flakey - but works - you just have to jiggle it sometimes to get the blade in. Also the rubber boot that covers the blade hold mechanism disitegrated quickly and is totally off. The Hitachi is holding up well but has not been used as much as the others to this point, but so far so good.
The Sawzall no longer works. The blade reciprocates in the air but when you try to cut something the blade stops despite the motor running and does not cut anything. The Sawzall it turns out is also made in China, but assembled in the USA. I have an old 11 AMP Sawzall - all metal that has lasted well over 20 years so far - this new unit is not that - nor that quality. The cutting seemed fine when it did work briefly (I am writing this about 40 days after we received the saw - it was used maybe 5 times). Also the blade holding mechanism is better than the Makita.
I called Amazon to exchange the unit they would not saying it was after 30 days. Fact is that Amazon does not support tool sales well, while we get better service from tool companies. So far I would recommend either the Makita or Hitachi - maybe even this unit (we might have gotten a lemon) but I would not order tools form Amazon in the future. Also looks like the price dropped about $20 on the tool from when I ordered it.
Corbofos
Corbofos
Гомель
14.03.2010 в 17:01:55
helmutivan написал : Вот и получается,Файн-у с его,как оказалось,проходными(для кучи) китайскими шуриками,место в элите, а Милку не пущать???
Да чего не пущать? Аргументировано убедили форум, и всё, Милка на уровень выше).
14.03.2010 в 17:03:33
ChVA написал : Кстати, насчёт это пилы (Milwaukee) есть и такие отзывы:
..к сожалению,знаю нормально только, матерный!:) там наверное негатив..?дык встречается....но примерно 1 к 20-ти позитива...Могу нарыть и редких охаиваний Файна и ,о боже,-Фестула...:)
ChVA
ChVA
14.03.2010 в 17:10:27
Там написано что человек работает бригадиром, покупает разный инструмент. Хитачи и Макита у него до сих пор пашут в тяжелом режиме, а Милуоки превратилась в действующую модель — по воздуху пилкой двигает, но не пилит при нагрузке.
Между прочим, с осторожностью относитесь к результатам работы гугловского переводчика. Он иногда меняет смысл на противоположный. Например, один товарищ пишет как замечательно работать такой пилой, а переводчик перевел что «страшно работать такой пилой» :)))
Бегемот86
Бегемот86
Нижневартовск
14.03.2010 в 17:10:30
Alex___dr написал : Кстати, Вы знаете, что означает S1 ?
"продолжительный режим работы", если я все правильно понял.
Suever написал : Фестула-быстрый ремонт,очень быстрый,гарантия 1+2 года,только не как у Хилти...
ну я, понятное дело, всех объединил. Каждый из 1-й группы имеет свои особенности, которые их и отличают от Макиты и Боша.
helmutivan написал : только не надо про ту.которая у Вас сломалась.
у меня ничего не ломалось. Т-т-т. Ладно. Поставлю вопрос иначе. Действительно ли Milwaukee есть тот же класс инструментов, что и Festool и Hilti с их конструкоскими и сервисными фишечками? Взяли бы вы их рубанок, а не Макитовский? Лобзик, а не Бошевский? ЛШМ? Чем реально круче их шурики по сравнению с аналогичными у конкурентов? Про Фестул и вопросов таких не возникает. Особая конструкция, особая оснастка, признанное лидерство.
14.03.2010 в 17:10:47
helmutivan написал : ..к сожалению,знаю нормально только, матерный!
...из кривого переводчика понял,что речь там о модельке "китайской". Я не вникал ,но возможно для НИХ,что-то из сабель там и собирается....Но про "настоящую-то как...? аж 20 лет сломать не может....:)
Corbofos
Corbofos
Гомель
14.03.2010 в 17:18:42
ChVA написал : Там написано что человек работает бригадиром, покупает разный инструмент. Хитачи и Макита у него до сих пор пашут в тяжелом режиме, а Милуоки превратилась в действующую модель — по воздуху пилкой двигает, но не пилит при нагрузке.
Решающую роль может играть человеческий фактор, зная как у меня на работе относятся к достаточно дорогому инструменту, можно предположить, что это присутствует везде. Достаточно было этому Милуоки попасть в "нужные" да ещё и молодые руки, и при стечении обстоятельств, капут.
14.03.2010 в 17:18:44
Бегемот86 написал : "продолжительный режим работы", если я все правильно понял.
А на каком оборудование ставится такое обозначение режима?
Suever
Suever
Оренбург
14.03.2010 в 17:19:43
Alex___dr написал : А на каком оборудование ставится такое обозначение режима?
На двигателе.:)
Gold_eggs
Gold_eggs
Мурманск
14.03.2010 в 17:20:41
Интересные наработки есть к многих брендов которые "наглотались" в своё время владельцев патентов, это - не повод пихать инструмент в вышую категорию.Каждая ТМ имеет свою наменклотуру, и сама принемает решение о введении OEM и пр. позиций. У TTI оч. широкие возможности, но качество, ресурс - обычные. Даже тот же LokTor - старик, ни в каое сравнение с протулом не идёт с его вентельным двигателем, эл. муфтой, 4я скоростями и "умными",Li АКБ.
ChVA
ChVA
14.03.2010 в 17:20:51
Corbofos написал : Решающую роль может играть человеческий фактор, зная как у меня на работе относятся к достаточно дорогому инструменту, можно предположить, что это присутствует везде.
Естественно. Но промышленный инструмент должен учитывать и такие вещи. Думаю что бедные латиносы на американских стройках тоже не трясутся над хозяйским инструментом.
