alex_k
alex_k
07.02.2007 в 14:18:21
alex_k написал : кстати подробный отчет итальянских мастеров
http://forum.il-legno.it/viewtopic.php?p=120676&sid=eb4f701f7266324467c1494a37a2da37
а статейка интересная особенно последние два абзаца
надеюсь из картинки понятно , что в таблице.
RILEVAZIONE A SALIRE:
Indice della scala.....Spostamento teorico.....Spostamento rilevato
..........1,5..............................0....................................0
..........1,0.............................0,5................................0,60
..........0,5..............................1..................................0,92
..........0................................1,5................................1,48
..........1,0*............................2..................................2,18
..........0,5.............................2,5................................2,5
..........0.................................3..................................3,05
..........1,0*...........................3,5................................3,75
..........0,5..............................4..................................4,09
..........0................................4,5................................4,63
..........1,0*............................5..................................5,35
..........0,5.............................5,5................................5,68
..........0.................................6..................................6,25
RILEVAZIONE A CALARE:
..........0.................................0....................................0
..........0,5.............................0,5................................0,5
..........1.................................1..................................0,82
..........0*..............................1,5................................1,54
..........0,5..............................2..................................1,89
..........1................................2,5................................2,38
..........0*...............................3..................................3,13
..........0,5.............................3,5................................3,64
..........1.................................4..................................3,95
..........0*..............................4,5................................4,68
..........0,5..............................5..................................5,21
..........1................................5,5................................5,52
alex_k
alex_k
07.02.2007 в 14:22:11
и продолжение 2 часть
http://forum.il-legno.it/viewtopic.php?t=12528
NickTol
NickTol
07.02.2007 в 14:49:46
С итальянским совсем плохо... Насколько я понял, они измеряли соответствие шкалы точной настройки глубины и факта для вылета фрезы на разных базах? Получилось хорошо или плохо?
NickTol
NickTol
14.02.2007 в 09:53:41
Ну вот.. Купил.. Упор прислали... Буду искать фрезы.
alex_k
alex_k
14.02.2007 в 10:48:55
NickTol http://freza.enkor.ru/ -наиболее полное описание из недорогих.
NickTol
NickTol
14.02.2007 в 11:03:30
alex_k Спасибо,этот каталог я уже изучил,выбрал на первое время. Теперь остается найти,где купить,желательно,в выходные.
alex_k
alex_k
15.02.2007 в 09:10:42
пока смотрел по фрезам наткнулся на интересное обсуждение шипорезок
http://forum.woodtools.ru/index.php/topic,1834.0.html
NickTol
NickTol
15.02.2007 в 09:47:19
alex_k Ну,до шипорезки мне еще далеко. Купил вчера энкоровский комплект 10560 http://freza.enkor.ru/frez8_1.php. Хвостовик у него под 12 цангу,посадочный диаметр 8. Насколько я понял,для того,чтобы поставить только один (или два) диска из комплекта, нужно прикупить дополнительные шайбы или лучше подшипники и ставить бутерброд подшипник-фреза-подшипник,добавив,если нужно,шайб? При этом подшипники должны быть одинакового (не важно,какого) внешнего диаметра,за счет чего будет опора на кромку с двух сторон. Шайбы нужно брать тоже у них,обычная штамповка не пойдет-даже если внутренний диаметр подойдет,все равно будет разбалансировка? И еще-к сожалению,эта фреза D=50,8 не проходит в отверстие параллельного упора. Поэтому,если делать паз за несколько проходов,придется либо менять подшипники,либо ставить направляющую,либо делать промежуточные проходы без опоры?
voland
voland
Иркутск
24.01.2008 в 13:38:36
Купил сегодня GMF 1400 CE. Сделал тестовые резы четырьмя разными фрезами. Впечатляет. Мягко, без вибраций, ровно, чисто, вообщем приятно. Работает тихо, даже не верится что 24 000 оборотов на 6 положении. Вибраций не заметил. Сделан в USA, даже не знаю хорошо это или плохо, покупал лобзик GST 135 BCE, сделан в Швейцарии. Везут от дяди Сэма такую даль. Надо срочно переводить все производство к нам в Иркутск.:D В комплекте нет параллельного упора и места для него в чемодане, буду заказывать на http://www.boschbuy.ru/ а так две цанги 8, 12, центрирующий конус для втулок, две втулки копир. два ключа, защита от опилок для обеих баз они разные, адаптер к пылесосу, винты какие-то. Особенно прикалывает копировальная база, встроенный лифт это нечто. Нет необходимости ломать голову, бери и ставь в стол, а там понадобилось где-то что-то вытащил мотор и в погружную, поработал ручками и быстро в стол. Чемодан тоже очень здорово, мне его возить придется. Все остальные фрезеры бошевские у нас продаются в картонных коробках. Странно, что в чемодане гнезда под фрезы на 6 мм (нет чтобы на 8 мм сделать) и 12 мм. Пока из недостатков только шнур, 4 метра, резиновый, но толстый. Неудобно этого удава пихать в чемодан.:cool: В общем первые впечатления положительные , а дальше жизнь покажет. Ну ладно надо это дело обмыть.
Vasskarr
Vasskarr
24.01.2008 в 15:04:41
Поздравляю с покупкой.
voland написал : Пока из недостатков только шнур, 4 метра, резиновый, но толстый. Неудобно этого удава пихать в чемодан.
Наоборот, это достоинство.
voland написал : Ну ладно надо это дело обмыть.
Только без фанатизма;).
alex_k
alex_k
25.01.2008 в 08:13:08
voland написал : центрирующий конус для втулок, две втулки копир. два ключа, защита от опилок для обеих баз они разные, адаптер к пылесосу, винты какие-то
копировальная база прекрасно ставится в стол. лифт уже задуман в конструктиве. для регулировки нужен специальный ключ. подробно разбирали здесь в двух темах http://forum.woodtools.ru/index.php/topic,4499.0.html
