Anat78
Anat78
Серов
23.09.2013 в 15:58:54
jimapwnz любого китайца 2х скоростного, если более работ не предвидится ,например такой http://www.vseinstrumenti.ru/akkumulyatornie_dreli-shurupoverti-r15.html/show_cat.php?formType=param&cat_id=15&id=15&submit.x=1&height=&search_type=param&clearFilter=0&makes[on]=1&makes[type]=check&price[from]=908&price[to]=24200&price[on]=1&price[type]=slider&price[min]=908&price[max]=24200&bdc[206139][ids_false]=&bdc[206139][on]=1&bdc[206139][type]=check&bdc[206573][ids_false]=&bdc[206573][on]=1&bdc[206573][type]=check&bdc[210454][ids_false]=&bdc[210454][on]=1&bdc[210454][type]=check&bdc[781][from]=9.8&bdc[781][to]=36&bdc[781][on]=1&bdc[781][type]=slider&bdc[781][min]=3%2C6&bdc[781][max]=36&bdc[1565][ids][13782]=on&bdc[1565][ids_false]=&bdc[1565][on]=1&bdc[1565][type]=check&bdc[469][from]=1.1&bdc[469][to]=5.2&bdc[469][on]=1&bdc[469][type]=slider&bdc[469][min]=1%2C1&bdc[469][max]=5%2C2&bdc[200294][from]=3&bdc[200294][to]=13&bdc[200294][on]=1&bdc[200294][type]=slider&bdc[200294][min]=3&bdc[200294][max]=13&bdc[421][from]=10&bdc[421][to]=76&bdc[421][on]=1&bdc[421][type]=slider&bdc[421][min]=10&bdc[421][max]=76&bdc[422][from]=6&bdc[422][to]=20&bdc[422][on]=1&bdc[422][type]=slider&bdc[422][min]=6&bdc[422][max]=20&bdc[200281][from]=2&bdc[200281][to]=125&bdc[200281][on]=1&bdc[200281][type]=slider&bdc[200281][min]=2&bdc[200281][max]=125&bdc[200329][from]=3&bdc[200329][to]=220&bdc[200329][on]=1&bdc[200329][type]=slider&bdc[200329][min]=3&bdc[200329][max]=220&bdc[1175][ids][12845]=on&bdc[1175][ids_false]=&bdc[1175][on]=1&bdc[1175][type]=check&bdc[1585][ids_false]=&bdc[1585][on]=1&bdc[1585][type]=check&bdc[1564][ids_false]=&bdc[1564][on]=1&bdc[1564][type]=check&bdc[204421][ids_false]=&bdc[204421][on]=1&bdc[204421][type]=check&bdc[206081][ids_false]=&bdc[206081][on]=1&bdc[206081][type]=check&bdc[98][from]=0.3&bdc[98][to]=5.2&bdc[98][on]=1&bdc[98][type]=slider&bdc[98][min]=0%2C3&bdc[98][max]=5%2C2&bdc[1423][from]=1&bdc[1423][to]=9&bdc[1423][on]=1&bdc[1423][type]=slider&bdc[1423][min]=1&bdc[1423][max]=9&guid=&orderby=price&asc=ASC или просто Hitachi DS10DFL
Костя G
Костя G
Стокгольм
23.09.2013 в 16:35:23
Anat78 написал : любого китайца 2х скоростного, если более работ не предвидится
Я бы не рекомендовал любого китайца. Дело в том что "любой" может не дожить и до трети ремонта. Если на то пошло, то можно поискать на секонд-хэнд рынке Б/Ушных качественных шуриков, и желательно с литиевой батарейкой. Если взять где-то подержанную/ые 10,8в-14,4 Li-ion Макиту или Бошика, то после всех вышеперечисленных дел можно будет его/их так-же и дальше продать чуть дешевле. Если вобще потом захочется продавать. У нас народ часто так делает.
Anat78
Anat78
Серов
23.09.2013 в 16:44:04
Костя G написал : не дожить и до трети ремонта.
указанные по ссылке переживут даже
jimapwnz
jimapwnz
Минск
23.09.2013 в 16:51:29
Hitachi DS12DVF3 2.0 что насчёт этого? Он вроде подешвле Hitachi DS10DFL. Собственно в чём разница? Я такой инструмент в руках не держал ни разу. И что насчёт всяких зелёных бошей и энхилей до 100$?
BECHA
BECHA
23.09.2013 в 16:54:49
jimapwnz написал : Hitachi DS12DVF3 2.0
у него никелевая батарейка и тяжелеее чуть-чуть литиевого собрата. 2.0 очевидно вторая ревизия. у первой был момент 25нМ вроде. вбейте "DS12DVF3" в поиск без кавычек - здесь целая тема отдельная про него, многие жалуются на то что зарядник кипятит аккумулятор и уменьшают зарядный ток.
Ssshaman
Ssshaman
23.09.2013 в 16:56:12
jimapwnz написал : Hitachi DS12DVF3 2.0 что насчёт этого?
Давно проверенный, недорогой и несовременный, но очень удобный шурик.
jimapwnz написал : Hitachi DS10DFL
Свеженький лёгкий литиевый шурик.
jimapwnz написал : И что насчёт всяких зелёных бошей и энхилей до 100$?
Не надо энхилей, если только Боша.
BECHA написал : 2.0 очевидно вторая ревизия.
Это очевидно ёмкость аккумулятора, бывают комплектации с разной ёмкостью.:yu Прежде чем утверждать что-либо не плохо было бы сначала вникнуть хоть немного в тему.
Homemaster
Homemaster
23.09.2013 в 17:16:27
jimapwnz, в ваших краях Hitachi DS12DVF3 самый доступный выход из положения. Только прочитайте тему и хотя бы штатный резистор в зарядке на минимум поставьте, и будет хорошо. Гипсокартон хорош для ускорения процесса получения оплаты труда, в собственном жилье он не нужен.
эго
эго
23.09.2013 в 17:17:06
Костя G написал : Ещё есть особняком японский пневматический MAX который буквально выстреливает саморезами в стену, питается от сверхсжатого воздуха (20 атм) который поставляется по шлангу двухпудовым компрессором. Вещь! Но он стоит как небольшой самолёт
Погуглил цены - такой комплект, как на видео ок. 180 рублей в РФ потянет, 41 рубль шурик, 35 рублей пистолет, ну и компрессор 112 рублей
telekin
telekin
Волгоград
23.09.2013 в 17:34:45
Костя G написал : Я бы не рекомендовал любого китайца. Дело в том что "любой" может не дожить и до трети ремонта. Если на то пошло, то можно поискать на секонд-хэнд рынке Б/Ушных качественных шуриков, и желательно с литиевой батарейкой. Если взять где-то подержанную/ые 10,8в-14,4 Li-ion Макиту или Бошика, то после всех вышеперечисленных дел можно будет его/их так-же и дальше продать чуть дешевле. Если вобще потом захочется продавать. У нас народ часто так делает.
Посмотрите откуда человек, это далеко не шведская местность...
Костя G
Костя G
Стокгольм
23.09.2013 в 22:20:38
jimapwnz написал : Hitachi DS12DVF3 2.0 что насчёт этого? Он вроде подешвле Hitachi DS10DFL
Для Вас оба этих варианта будут вполне подходящи. Мелкий шурик реально получше, даром что мелкий, но здоровый слегка помощнее и много жалоб на батарейки. Вот не знал что проблема в заряднике. Если имеете дома электродрель или перфоратор то запас мощности не нужен, и из этих двоих порекомендую мелкую Хитачу. Ей бы патрон породистый- вовсе была бы бомба, но такой патрон стоит половину её цены. Ейнхели бывают профессиональные и бытовые, различаются цветом- красные и синие. Первые так для дома-гаража ничего, вторые не рекомендую вобще. Зелёный Бош в принципе хорош всем, им можно работать даже профессионально. По своим характеристикам он вполне на уровне средних проффмоделей других марок и синего Боша (синий- профф, зелёный- бытовой), разница в ресурсе. Бытовой (хороший бытовой) инструмент при ежедневном использовании на стройке служит несколько месяцев в то время как профессиональный- несколько лет. Грубо говоря в этом основная разница, в том числе и ценовая. Вам Милуоки не нужен, а зелёный Бош вполне удовлетворит все потребности по ремонту и на несколько лет вперёд по всяким "тут подкрутить-там просверлить-на даче забор поправить"... Кстати, Хитачивский 18в шур, который Вы рассматриваете- это не проффмодель а бытовая. Хитромудрые японцы ввели недавно серийи semiproff, где продают недорогие модели задёшево. Но это не дерьмо, просто у них по сравнению с их обычным инструментом ресурс короче, труба пониже и дым пожиже...
telekin написал : Гораздо выгоднее купить универсальный, всё равно большая часть времени по неопытности уйдёт на размышления, - "что, да как".
Абсолютно солидарен с данным тезисом!
telekin написал : Посмотрите откуда человек, это далеко не шведская местность...
Не вижу принципиальной разницы. Впрочем, может потому и не вижу что издалека не видно...
hugos
hugos
Смоленск
23.09.2013 в 23:45:05
Ssshaman,Вов давай ролик снимем,как попадеться гипсокартон,с 886 девольтом,с битой ограничителем и браслетом магнитным там скорость недалеко отстала от магазинных
