Па
Па
Серпухов
01.04.2021 в 00:42:20
http://yandex.ru/clck/jsredir?from=yandex.ru%3Bsearch%2F%3Bweb%3B%3B&text=&etext=2202.BYiSfB4Q5LaM5U3zFqOFA4CAMDz9qYoBXWwWMrD7sIA3W08WB02mj47evC2AWL5MYmp5xg8eCZtyn42wCWrQfGxta3Nja25jYnJhb3l1c2g.c675381e99743ef0f576b70716489b959a326eed&uuid=&state=jLT9ScZ_wbo,&&cst=AiuY0DBWFJ5Hyx_fyvalFAWFo09qF2ERvPgU1rfYgXn6WGyPxRW0dgYh8P8IQm9PoxhtkKYEHwGx0NchlH-IByfEcYdnn2o-KBFafJbJAe9T4FxnUK3kbobC42x0J9EBG3utQ77yHEBZfF_U2HxetVf88UXyI1i0JjlzJthq_tgcMln3hDq_2tdq6fU6Su6pQaEykNpJ_Wa1bCW29tkLMpK5FBASMqKlwNCosYDYsICV_7ttEWOBNVPKaHS7Cu1_G20Xci34ofFrsX7gFUyD5aVuRmgDJDB9V7zdldufJX83wf5y7b5SrvYEtJPBQk8gf4-VAD8BL_SdkFMGP6zz0f_UeoaLUbEI2gx6xPJT3AAVqWg6m-H9AVdTr-l6FQ0bk-iUCF4kHYL31T7XMg9zFSoiXJGAH4Jci9xHbPVj5CWko8qww1WHyjsu9U-k_HFd_ANMJsDDrCVQ3mvYSyBQhuBJfDa5yuW8rackJEMzv7owAeLDQdQtl5KYPRlDiF1V80-h_XRqykbDKdMq-077JRGtUY6rpZPqpkBYq0HRHf49m2-qlYADC0hmGc_DDG06mLgeJU5A5C7tiLIwiiwocRR_TJd3T027-9lvTQ3uy3fcWjU3pb7EDDhjnVExRMVSmrBJ4O9e-0oEarMqMiueHEaAhS99ltYGP1q4npFriD95oqvebiIqK-phHHUmcsGHQGYMowfxuprW5yVab_u2IuW9_3amFFuG1irdzltnCA7i6h_a5Rb5GBDBYtTSiJdRfRPrd-olQ4_CAMpaXbC_6bDQLSPEnBMF3fe2Dx-YzTwKAyOUPRUaWsR7Lghl6LOvz4PdWDDUEAG1wDthAvIL_ZBTHSQ0S_L-MNFLokoroKOnE2kKYAT-7Dv3zl-8gWNv96qirBUT4ugFa_pVGoCT4N2FruLDR4wcGK3xaP-mB7-y3i0SPMEwuO3E0YjN7C-GqMJFV8ulTNZNUDULctVaw9Rp63nOWl8mOvsgNv3O_e-Es523bJQr5iXxSZ_PpTIV7bdv6Axjk3_7k6N32E2n56EDsJG4wgcKb5ozVRgvg_yh25nNl8Zm3-miAuGispzH-NPI6L95IWEh968turiah9R9YCT8KrTYLui9TOsi35h9Gm4ApKXZaRpQCq5ZU-43vLkVMyz1bc1HYFAv-PNRrg,,&data=UlNrNmk5WktYejY4cHFySjRXSWhXSFRvUjljUWdhcE1WT19BMG5lTUp4TG9QdC1XTkxBZFdmRTJJdUt0eE1acWRqWm5SRFdxWmpUQkNVTl9sZWRnNEZGTGJUMHpOMzIyM0RWU1JzbTBySzYyUmszSWN4NUg4dFFCNDl6VC1xQWNzeVlKeXVKS1VRV2pqMjFiNGFQMDVBLCw,&sign=aa89abcb22b309da48f73019aef79b67&keyno=0&b64e=2&ref=orjY4mGPRjk5boDnW0uvlrrd71vZw9kpRGJgA8ksnbnVQMfd35B4RiGEZt-ocu6flC87YLqqhT65DNp6BGndUf3kitI6Z3Hhz5ab_1FsbSaP09OIlUQjSByW0IKJxfmWs7NnQAYTBE97wmMo0w3l_zu1Lp2kTC0zypcS_T448eE7a0z-wyS72-TXxt67gYx-SsSPKSNRG8uq7xkLY6IdRQrw99cXOpfJjzwvqvzQ_D3FruNk5FsWD6j1YPGDiygJmScgJFAgp2xd4t7yo-emZA,,&l10n=ru&cts=1617226923876%40%40events%3D%5B%7B%22event%22%3A%22click%22%2C%22id%22%3A%225in55v%22%2C%22cts%22%3A1617226923876%2C%22fast%22%3A%7B%22organic%22%3A1%7D%2C%22service%22%3A%22web%22%2C%22event-id%22%3A%22kmxz5krot3%22%7D%5D&mc=4.7861221674133505&hdtime=993443
Sergey Michailovich
Sergey Michailovich
Липецк
01.04.2021 в 21:41:50
pumazavr написал: 3 шт шайб это типа регулировка?
Можно сказать и так или увеличение уплотнения но в вашем случае судя по видео этих 3 шайб будет маловато и желательно выяснить какая должна быть родная форсунка по каталогу.
pumazavr
pumazavr
Псков
07.04.2021 в 17:00:26
чуда непроизошло...купил 2 теплоизолятора на 7 (Кольцо уплотнительное форсунки 170F, 178F, 186F, диаметр 7 мм) и 8 (Кольцо уплотнительное форсунки 170F, 178F, 186F, диаметр 8 мм)
...форсунка на 8мм..с толстой медной шайбой начало поджиматься..появилась какаято компрессия но всеравно сифонит..теплоизоляторы Материал - пластик хрупкий какойто. возможно не получиться запчастями с китайского клона починить оригинал... оригинальный теплоизолятор тоже пластик? или резина? размеры его где мона найти? двиг оказался L100AE
Па
Па
Серпухов
07.04.2021 в 19:05:11
pumazavr, Приветствую! Да сейчас всё что угодно можно найти и в том числе на этот двигатель. !#[https://youtu.be/bnh88iXfYMY] поговорите с этим пользователе из ютуб, да и посмотрите его видеоролики
pumazavr
pumazavr
Псков
07.04.2021 в 19:53:25
Па, да мнеб лучше человека у которого оригинал двиг как и у меня ,чтоб сравнить детали с китаем
Саныч53
Саныч53
Великий Новгород
07.04.2021 в 20:49:16
pumazavr, приветствую! В свое время под форсунки автомобильных дизелей ставил самоточные фторопластовые кольца. При затяжке форсунок они деформировались и надежно уплотняли посадку. Применение разовое, снял и выбросил.
КМЗ-012ч 2004 г.в. 5+1
Па
Па
Серпухов
07.04.2021 в 21:08:54
pumazavr, у меня такой и как вы мыслите разбирать двигатель? Вы свой янмар разбирали?
pumazavr
pumazavr
Псков
07.04.2021 в 22:07:36
Па, мне нужны размеры оригинала этого теплоизолятора чтоб сравнить с китайским клоном
Саныч53
Саныч53
Великий Новгород
07.04.2021 в 22:16:45
pumazavr написал: Па, мне нужны размеры оригинала этого теплоизолятора чтоб сравнить с китайским клоном
pumazavr, Вам таки шашечки или ехать?
pumazavr
pumazavr
Псков
07.04.2021 в 22:19:29
Саныч53, вашь вариант на крайний случай
