Па
Па
Серпухов
26.03.2016 в 12:59:32
bulbash написал:
Садовник_ написал: Мне одному кажется, что голландцы крупную картошку сажают
Я в этом году тоже на семена попробовал крупные(100гр.и больше)клубни оставить-по осени посмотрю на результат-в сравнении с традиционной(50-80гр.)технологией.По ролику:интересно,чем это поле посыпано до посадки картофеля?Не золой же... :confused: И какая ширина междурядий,на вид-не менее 75см... публикация к фото по этому видео.
bulbash, https://upload.wikimedia.org/wikipedia/commons/thumb/7/70/Spreading_lime_on_a_Devon_field.jpg/1024px-Spreading_lime_on_a_Devon_field.jpg наверно это препараты для раскисления почвы.
Liming (soil) From Wikipedia, the free encyclopedia Liming is the application of calcium- and magnesium-rich materials to soil in various forms, including marl, chalk, limestone, or hydrated lime. This neutralises soil acidity and increases activity of soil bacteria. However, oversupply may result in harm to plant life. Lime is a basic chemical, the effect of it makes the soil more basic thus making acidic soils neutral.
Liming of a field in Devon The degree to which a given amount of lime per unit of soil volume will increase soil pH depends on the cation exchange capacity (CEC). Soils with low CEC will show a more marked pH increase than soils with high CEC. But the low-CEC soils will witness more rapid leaching of the added bases, and so will see a quicker return to original acidity unless additional liming is done.
Over-liming is most likely to occur on soil which has low CEC, such as sand which is deficient in buffering agents such as organic matter and clay.[1]
Most acid soils are saturated with aluminium rather than hydrogen ions. The acidity of the soil is therefore a result of hydrolysis of aluminium.[2] This concept of "corrected lime potential"[3] to define the degree of base saturation in soils became the basis for procedures now used in soil testing laboratories to determine the "lime requirement" of soils.[4]
An agricultural study at the Faculty of Forestry in Freising, Germany that compared tree stocks 2 and 20 years after liming found that liming promotes nitrate leaching and decreases the phosphorus content of some leaves.[5]
Садовник_
Садовник_
Иваново
26.03.2016 в 14:36:50
Па, Перед посаждкой картошки, почву, как правило не раскисляют. Кальций вносят под предшевствующую культуру.
Па
Па
Серпухов
26.03.2016 в 14:45:11
Садовник_, это так, у кого какие препараты есть, зола, известь и т.д..
Па
Па
Серпухов
26.03.2016 в 14:51:02
https://youtu.be/SGzTSBeUMWs возможно вот так обрабатывают земля перед посадкой
alena1976
alena1976
26.03.2016 в 21:08:45
Кто нибудь режет картофель? Действительно растет урожайность?
bulbash
bulbash
Беларусь, Дятлово
27.03.2016 в 21:03:08
Па написал: это препараты для раскисления почвы
Соглашусь с Садовником:
Садовник_ написал: Перед посаждкой картошки, почву, как правило не раскисляют. Кальций вносят под предшевствующую культуру
Па написал: возможно вот так обрабатывают земля перед посадкой
Интересно,в чем преимущество трехколесного трактора перед традиционной компоновкой? :confused:
Па
Па
Серпухов
27.03.2016 в 22:56:08
Па написал: https://youtu.be/SGzTSBeUMWs возможно вот так обрабатывают земля перед посадкой
Па, Возможно обработка ведётся не перед посадкой, видео опубликовано в декабре.
RoodeK
RoodeK
Сумы
31.03.2016 в 09:21:17
bulbash написал:
bulbash, Думаю для уменьшения давления на почву, то-есть для равномерного давления на единицу площади.
Марош
Марош
Барановичи
31.03.2016 в 14:52:40
RoodeK написал:
bulbash написал:
RoodeK, Все так. Осушенное болото. Видны мелиоративные каналы. Покрышки колес ... .
Александр12
Александр12
02.04.2016 в 13:47:09
Немного не по теме вопрос.В погреб зашла вода,поднялись грунтовые воды.Пока вытащить и просушить картошку нет возможнсти,пропадет картофель,семенной,если пробудет в воде около недели?Вода и до этого попадала,но успевали вытащить картошку сразу же,потому последствий не знаю.
jek
jek
Липецк
02.04.2016 в 14:40:29
Александр12, конечно, за неделю нахождения в воде картофель начнет гнить.
