2НиколаКо
Permatex® High Performance Thread Sealant это все таже песня:
TYPICAL APPLICATIONS
Recommended for sealing metal tapered pipe threads and
fittings up to 5cm (2 inches) National Pipe Thread (NPT) for
industrial applications in the chemical processing, petroleum
refining, pulp/paper, waste treatment, textile, utilities/power
generation, marine, automotive, industrial equipment, gas
compression and distribution industries. It is also
recommended for industrial plant fluid power systems.
• Stainless steel fittings
• Head bolts into through holes
• Oil PSI sending units/sensors
• Fuel fittings
• Oil and coolant lines
• Hydraulic line fittings
• Brake fittings
• Transmission fluid fittings
• PTO fittings
• Air conditioning fittings
