сансэй
сансэй
05.10.2008 в 17:33:34
Перечень пресс-фитингов, профиль ТН
ALB Sistema Multicapa
APE Raccordi
BAMPI BALPED, BAMPI BALPEX
Brasstech Brasspress Aluplast
BUCCHI tech MP
ClouSet Press
Comap Multiskin Gas
Comap Sudopress Skin Visu-control / Skin Gaz / Skin Plastic
CosmoCONNECT
cusmart
Dalpex LaserMultiDalpex
DiaNorm HKS Sitec Press
DIWAflex systems
egeda Comisa
EMPUR PEXPRESS
eurotherm Multistrato Euro2000
FAR Rubinetterie PRESSFAR
gabo Systemtechnik
GAROS
General Fittings General-Flex-Press 5900
Giacomini RP multistrato/ GIACOFLEX/ GIACOTHERM
GS Warmesysteme System TH
HakaGerodur HAKASAN
Harden 2000 Poly-Pex 2000
Harden 2000 Plastic-Press
heima-press
Henco
Herz pipefix
HITEC Sistema Multistrato
Idrosanitaria Bonomi sistema multistrato
IDROSISTEMI TA-PRESS
IPA IPANA-Press
IPALPEX
IVAR MULTIPRESS
Jaraflex- Presssystem
KuBuS
Lagerstedt & Krantz LK Universal
Largo-Presssystem
Mark KG Polymark
Ma.s.ter System PRESSMASTER
MULTITHERM- PRESSSYSTEM
Nicoll MULTIPROJECT
Pietro Ravani S.p.A. PRESS-Me
PIPELIFE- RADOPRESS
POLYSAN Handelsges. m.b.H. & Co KG (Krems - Osterreich)
PRASKI BAVARIA-press
PURMO HKS Sitec Press
RIFENG TH PRESS FITTING
Rofix Rhino Pex
Roth Espana Rothapress
Rubinetterie Bresciane Bonomi TURBO PRESS
Schlosser EUROPRESS- SYSTEM
SCHUTZ EHT rOpress
SIKO TYPRO, SIKO TYROTHERM
Simplex SiRoCon Installationssystem TH
TEKNOCOBRE sistema multistrato
THERMAGAS Espace Espress
TIEMME COBRAPRESS
Trefimetaux Qtec
TUBOPLAST sistema multistrato
Van Marcke Tu-Bi-Pex
Variotherm System TH
Viessmann
V.I.Trade VITerm
Watts MTR Art press
WeeConFlex MVR
Winkler
WKS-Press
Zetaesse Multistrato EUROPEX/ ISOPEX
Zetaesse Rame HydroSAN/ ThermoSAN
ZEWOTHERM
сансэй
сансэй
05.10.2008 в 17:34:10
Перечень пресс-фитингов, профиль Н (HA)
AC-FIX PRESS (Global Piping Systems)
AC-FIX PRESS-MULTI (Global Piping Systems)
BARBI MULTIPEX (Industrial Blansol)
CosmoCONNECT
Fimisol HAKAPRESS
Frankische alpex F50 PROFI
FRIATHERM uni
HakaGerodur HAKAPRESS
IVAR MULTIPRESS
Jager aquapress H
KuBuS
Mair Heiztechnik Gomafix M
Mair Heiztechnik M-Press
MEGARO HAKAPRESS
NEUTHERM MEKUPRESS-HT
O.M.T. Heizungssystem
Oventrop Cofit P
Polytherm Polyfix, Polytherm Polyfix-MT
Prandelli MULTYRAMA
remo
RIQUIER A SERTIR
Roth
Simplex SiRoCon Installationssystem H
SLOVARM PEX-THERM
Systerm WELCO-Flex
THERMOLUTZ acular/rapid
TKM Fellingsbro TKMPRESS
Ulrich VARIOFLEX-HAKAPRESS
Valsir PEXAL
WEFA PLASTIC WEFATHERM-PRESS
WEM
Wirsbo-Velta biroduct P/Fusbodenheizung/rapex multi
сансэй
сансэй
05.10.2008 в 17:34:48
вот выберайте:)
KonstantinK
KonstantinK
05.10.2008 в 17:36:18
Ааааа...за что....:cool:
сансэй
сансэй
05.10.2008 в 17:41:42
KonstantinK написал : Кое-что изиенил
а места в шкафу хватит?? для фильтров совмещённых с колекторами + нужно учесть краны и отводы на водогрей
сансэй
сансэй
05.10.2008 в 17:52:54
воще к медному пластику(который вы собираетесь брать) лучше взять фитинги производителя и у них узнать что к чему (про прес губки , переходные фитинги итд)
сансэй
сансэй
05.10.2008 в 19:28:12
вот ещё что на бойлер нужен только один кран сливной
хотя ставят ина подсос воздуха но ..
лично я ставлю всегда один и всё нормально сливает:)
freetron
freetron
06.10.2008 в 00:46:35
KonstantinK Жаль что не удалось отговорить вас от такого порядка девайсов разводки в пользу правильного :) Как последний аргумент хочу посоветовать посмотреть в какой последовательности идут девайсы в работах хороших мастеров. А если есть еще и симптомы сантех паронойи ;) - можно поставить защиту от протечек с электроприводом крана (или с электромагнитным клапаном, но это имхо хужее и есть особенности).
И еще пара моментов по имеющейся разводке. А обр. клапаны (после счетчиков) будут? ЗАчем кран после фильтра ГВС? Я понимаю, что при отключении ГВС он закрывается, открывается кран на бойлер. Но не логичнее тогда закрывать отсечной кран на стояке?
PS Когда отключают воду я обычно закрываю кран на стояке, и открываю только когда дадут воду и пройдет некоторое время, чтобы особо "быстрые" слили всю грязь и пошла чистая вода.
сансэй
сансэй
06.10.2008 в 00:50:27
freetron написал : Как последний аргумент хочу посоветовать посмотреть в какой последовательности идут девайсы в работах хороших мастеров
freetron. это намёк что я не хороший:a
freetron
freetron
06.10.2008 в 01:03:57
Ни в коем случае, сансэй! :) Извини, если получилось двусмысленно :( Часто вижу именно когда редуктор стоит именно после фильтров... У меня то с этим проще, фигли - HW FK06, и то и другое и сразу и вместе. Смотрел я их устройство, получается что там тоже вода сначала попадает в колбу фильтра и потом идет редуктор.
KonstantinK
KonstantinK
06.10.2008 в 02:41:55
freetron написал : Жаль что не удалось отговорить вас от такого порядка девайсов разводки в пользу правильного
А я вот до сих пор уверен в правильности своего варианта.:o
Работы мастеров смотрел, конечно, перед тем как начать "творить" самому. :)
Кто знает, м.б. скоро это станет новым стандартом сантехстроения... :D
freetron написал : А если есть еще и симптомы сантех паронойи - можно поставить защиту от протечек с электроприводом крана (или с электромагнитным клапаном, но это имхо хужее и есть особенности).
Рассматривал вариант. Но либо очень дорого, либо доверия не вызывает. Может и не там смотрел. Но перебор, ведь, тоже плохо.
freetron написал : И еще пара моментов по имеющейся разводке. А обр. клапаны (после счетчиков) будут?
Пока не знаю. Слышал про это, но не успел изучить необходимость. Просветите, если не сложно. :applause:
freetron написал : Зачем кран после фильтра ГВС? Я понимаю, что при отключении ГВС он закрывается, открывается кран на бойлер. Но не логичнее тогда закрывать отсечной кран на стояке? PS Когда отключают воду я обычно закрываю кран на стояке, и открываю только когда дадут воду и пройдет некоторое время, чтобы особо "быстрые" слили всю грязь и пошла чистая вода.
"Вводной" кран, само собой на период отсутствия ГВС будет перекрываться.
А этот шаровый (со входа коллектора ГВС) призван исключить проход воды по магистрали в обратку, до вводного крана (частично, как мне представляется, выполняя и ф-ции описываемого Вами обратного клапана (в области счетчика).
